TwinTurbo.NET: Nissan 300ZX forum - Re: Were both tests completed on a warm or cold engine?
eldergolfer21
on May 15, 2020 at 11:07 AM
Were both tests completed on a warm or cold engine? (n/m)
posted by MixManMash
on May 15, 2020 at 05:20 AM
Engine was warm when doing both compression tests
Low compression on all 6 after doing full OEM gasket kit
eldergolfer21
13:41:52 05/14/20
Re: Low compression on all 6 after doing full OEM gasket kit
Cjw3
15:07:21 05/14/20
Re: Re: Low compression on all 6 after doing full OEM gasket kit
eldergolfer21
20:14:58 05/14/20
OK.. this info helps
Cjw3
02:21:36 05/15/20
Re: OK.. this info helps
eldergolfer21
11:06:22 05/15/20
Re: Re: OK.. this info helps
Cjw3
12:01:47 05/15/20
Re: Re: Re: OK.. this info helps
eldergolfer21
13:04:17 05/15/20
MixManMash
05:20:23 05/15/20
Re: Were both tests completed on a warm or cold engine? -
eldergolfer21
11:07:15 05/15/20
eldergolfer21
17:35:52 05/22/20
I would do a vacuum test then a smoke test it to see if >>
ZUL8TR
04:55:59 05/24/20
